Salta al contenuto principale
Touch not working properly Automatically touches happens
Questa è una buona domanda?
Punteggio 0
2 Commenti
thats weird tho, i have the same issue, no automatic touches, this happened very unsually
da
changed from an answer left on Phones display is not working to its own question
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The phenomenon known as "ghost touch" results from a bad connection between the digitizer and the motherboard, allowing signal noise on the line which gets interpreted as touch inputs by the processor. The interface between the glass the digitizer circuitry is printed on and the flex cable going to the motherboard is delicate and easily broken. Unfortunately, it's not repairable so the only solution is to replace the screen. Assuming you have the same phone as the original poster, you can use the instructions given in my answer to fix your phone.
Here is a link to that answer.
Phones display is not working - oneplus nord ce 2 - iFixit
Punteggio 2
2 Commenti:
I want to repair it
da
@prashantsh30375 You'll have to be more specific. What's broken that you want to repair? If we're still on the subject of ghost touches, that's already been answered, and if it's a different subject or a different phone, you need to start your own question with a good description of exactly what the issue is, how it started and what you've done to troubleshoot the problem.
da
Aggiungi la tua risposta
myself Chotu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 255
