Salta al contenuto principale
Il nuovo formato di Apple per la linea 14 ha uno schermo OLED da 6,7 pollici, come il Pro Max, ma le stesse caratteristiche dell'iPhone 14 con doppia fotocamera e chip A15 Bionic con una GPU a 5 core.
iPhone 14 plus reboot randomly
Hello everyone, I'm posting a message here because my phone (iphone 14 plus) crashes and restarts by itself, I have the crash report, I need you to try to solve the problem, it's been like this for a month now, it's driving me crazy, I've switched back to the iphone 8 plus just long enough to understand, so if anyone has a solution I'll take it! https://pastecode.io/s/qoixm17c
Questa è una buona domanda?
Punteggio 0
1 Commento:
Your iPhone may have a damaged battery, or it has a damaged. internal part. Maybe iOS itself is corrupted and needs to be restored, if that's the case then you will need to restore the phone using iTunes.
da
Aggiungi un commento
1 Risposta
I had similar issue, was under Apple Care, they rebuilt the entire phone. At a service center, it was great till Apple care ended, a few months.
Back to the same issue, random reboots and now randomly heats up.
Tried:
Removed protective case.
Turned off all background apps
Turned off app updates/refresh.
Deleted apps.
Do not carry in my pocket.
Bought a new Apple Charger/cord.
Do not use the induction charger any longer.
All this helped but still have the issue it is all random.
Do not expect a lot of help from Apple.
Irony, I traded up from I phone 11 with no issues, to the 14 plus, that was great for a few months.
Good luck!
Punteggio 0
Aggiungi la tua risposta
Matheo Maufroy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 39
Tutti i Tempi: 312
