Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
Part number for Fan Connector ZIF Connector
Hi,
I am looking for the part number for this ZIF connector pictured, which connects the fan to the case. I'm sorry I don't have a picture of it with the tape removed, I forgot to take this picture.
I removed this part to clean the fan and the little plastic "clip" that holds down the ZIF connector broke off. I'd like to try and find a new one to see if I could re-attach the "clip" (or worst-case scenario the whole connector with some micro-soldering) but I cannot figure out this part.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Don't know the part number, but I think this has what you're looking for—the "No 2" option is the 5pin fan ZIF connector for the A1708. You could also look for a damaged or used top case online and get one of those to pull the connector clip from. Good luck!
Punteggio 2
4 Commenti:
Thank you @zpl ! I ordered that, will respond here and accept as the answer if it works. Appreciate you finding that link!
da
No problem! Glad to help!
da
This part arrived and it was exactly what I needed, great find! I was able to replace the "clip" and the connector worked as expected. Thanks again!
da
Awesome! Glad to hear it was a success!
da
Aggiungi la tua risposta
mark sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 106
