Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
Trying to use terminal to disable auto boot
Can’t get terminal to disable auto boot using sudo nvram AutoBoot=0%
Seems like nothing happens after imputing me password
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Are you following the steps in this guide? Note also that when the command executes successfully it doesn't really give you any feedback, it'll just go to the next terminal prompt. You can check to see if the command was successful by shutting down the device and closing the lid. Then open the lid and see if it auto boots. If it doesn't, then you're good to go! Good luck!
Punteggio 1
Aggiungi la tua risposta
Blair Aston sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 81
