Salta al contenuto principale
Ninth generation of iPad, released September 24, 2021, available in 64 or 256 GB models. Model Number A2602.
iPad 9 black screen. I can see screen if using flashlight
I have an iPad 9th gen. Recently the black screen of death appeared. I restored it and nothing happened. I saw a post about if you hold a flashlight to the screen and see it that means it’s the back light. I did that and sure enough I can see it. If that’s the case, would I have to replace the LCD screen? Or is it irreplaceable. Could it also be a loose cable?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
  1. The back light is part of the screen assembly. A new screen ‘should’ fix it, however it’s also possible a backlight ic or something similar has blown on the motherboard. 9 times out of 10 a screen replacement should fix the issue.
Without examining anything I can’t be certain no guarantees but a screen replacement will most likely fix this.
Punteggio 2
The issue is with the backlight flex cable — it’s torn underneath the metal shield. I’ve repaired many iPad LCDs with similar no-backlight problems.
Punteggio 0
Aggiungi la tua risposta
Jacqueline Alanis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 104
Tutti i Tempi: 993
