Salta al contenuto principale
Dell XPS 13". The smallest 13" laptop on the planet that also has the world's first virtually border-less InfinityEdge display, as claimed by Dell. Released in 2012.
The case is swollen
the battery is swollen
Questa è una buona domanda?
Punteggio 0
1 Commento
You will need to remove the battery and replace it.
Exactly what model is your DELL XPS 13 Series laptop?
da
Aggiungi un commento
1 Risposta
Risposta più utile
@letcherross time to take it apart and to replace the battery. You do not want to continue to charge your battery. That can make a bad situation worse. Use the Dell XPS 13 Service Manual to replace it. Page 16 will tell you how to accomplish the task. Discard the old battery properly. Don't just toss it in the bin. Check with your local environmental agencies on how to properly discard it.
Punteggio 1
Aggiungi la tua risposta
Letcher Ross sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 9
Tutti i Tempi: 133
