Salta al contenuto principale
Lanciato a novembre 2020, il MacBook Pro da 13" ha il SoC basato su ARM M1 di Apple con una CPU octacore e una GPU octacore. (Modello A2338 / EMC 3578 con due porte Thunderbolt 3)
Why is my MacBook Pro say Service Recommended after replacement?
My Macbook Pro battery indicator still says Service Recommended with an X in it after having replace the battery. I tried to do the battery calibration but it wasn't showing me the percentage on it. I know it was a brand new battery so I tried to restart the mac multiple times to pretty much no avail. I haven't drained the battery yet to calibrate it because it is not showing that it is actually charging and at 100%.
It would show it getting power, but later it would say not charging and service recommended. I have also tried the smc reset on it but it didn't work because the battery needed to stay plugged in for it to turn on or something I don't know.
Is their anyone that can help me reset the battery indicator or fix my problem in general?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Let’s get a better view of things, install this gem of an App CoconutBattery post a snapshot of the apps main window while the charger is plugged in. Post it here so we can see as well.
da
Aggiungi un commento
2 Risposte
Finder / Prefs / Sidebar / Locations / tick under icloud the mac
Navigate then to mac HDD / Library / Prefs / delete the 3 files com.apple.power. Empty the trash & restart. Best to do this when the battery is at 100% charge.
Maybe that helps?
Punteggio 0
It still has a cache memory of the previous battery. Do a vram reset CMD+ALT+P+R
Punteggio 0
Aggiungi la tua risposta
Luke Hyde sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 139
