Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
Domanda Chiusa
4s mirror back plates kills wifi signal?
Hallo, i have a problem , i tryed to change back plates from my black stock apple back, to one of those silver mirror type, i did a color conversion and it all worked fine exept when i installed the silver back plate i get vey bad wifi, i also have a gold coversion kit, just to see if it would be the same i tryed putting on the gold mirror back and again get very bad wifi, it does work but the speed is very unstable and the ange limitet compared to with my stock black back plate??? I also tryed a red one and it seemed to work without any problems, so it seems the problens is with the morror versions??
Any ideas and solutuons to a fix???
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi there,
Metallic plates, or paint that contains metallic particles will block the WiFi radio signals in the iPhone.
As much as you want to personalize your iPhone, I would recommend you'll refrain from any 'bling-bling' that obstruct the radiosignals (goes for BlueTooth, GSM and Wifi)
Rgds
Robbert
Punteggio 0
1 Commento:
hallo Robert thanks for a reply but it just seem so strange that they sell these mirror kits when they simply don't work, well the front is no problem but the back plate apparently kills the wifi, I have a kit in silver and one in gold both of them makes my wifi very sucky, it's working but the range is very limited, I would hope there was a solution of some kind how to get it working...?
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,247
