Salta al contenuto principale
Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
How repairable is the hardware microphone mute button?
The mute button for the microphone seems to have a loose connection, as when I turn the mute on or off, it beeps and randomly activates/ deactivates the hardware mute until I tap the left earpiece. I'd rather avoid replacing the whole headset due to the price.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Somone said they used wd-40 contact electric spray on it and that solved it, others say you keep pressing and unpressimg the mute button, if you still have warranty contact manufacturer.
If you're a tinkerer you can disassemble the headset and clean the mute button from the inside, if that doesn't solve it then I would put a small solder point on its tip from the inside and keep it unmuted all the time and not play with it, maybe use software matting instead after.
Punteggio 0
Aggiungi la tua risposta
Corey Sutlief sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 65
Ultimi 30 Giorni: 321
Tutti i Tempi: 1,508
