Salta al contenuto principale
Wifi not working and not connected
Wifi not connected and not working
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello! I’m happy to help!
This can be caused by a lot of things. There are a few things that we can try.
First, is your router plugged in and turned on? Your router is a box with cables connected to it with lights on the front.
Second, on the back of it, there should be a cable connected to the back of your router in a port that is usually labeled “ONT WAN”, or “Broadband”. The port should also have a light on it.
There should be a few lights on the front or top of your router. The ones that should be on are the power light (it looks like an circle with a line), broadband (mine looks like a squiggly line, but yours could be different) and Wi-Fi signal broadcast light (looks like a dot with several curved lines above it), and finally, an internet connection light that looks like a circle with a bunch of horizontal and vertical lines running through it.
Last, is Wi-Fi enabled on your phone? You can check this by going to settings (swipe up from the home screen and tap the gear icon on your phone)-> Connections (it should be the first option)-> tap on Wi-Fi and select your network( you can usually find your network name (SSID) and password on a sticker on your Wi-Fi router.
I Hope this helps! Feel free to reply with any more questions you have!
Punteggio 0
Aggiungi la tua risposta
Fnky Sid sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 96
