Salta al contenuto principale
First generation, based on the Ford C1 global platform.
How to change Gasket seal
2004 mazda axela. Engine leaking I have seal but not sure how to replace
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi robyn,
Can you be a little more specific? Exactly which seal did you buy? There are several on any given engine, so it's important to know which one you're trying to change.
da
Aggiungi un commento
1 Risposta
  • Prepare the Vehicle: Park on a level surface, disconnect the battery, and ensure the engine is cool.
  • Locate and Access the Gasket: Identify the leaking gasket, and remove any parts obstructing access.
  • Clean the Surface: Remove old gasket material and clean the area around the gasket.
  • Install the New Gasket: Place the new gasket in position. Apply sealant if required.
  • Reassemble and Check: Reinstall removed components, tighten bolts to specifications, and check for leaks after starting the engine.
Punteggio 0
2 Commenti:
This looks like a typical AI generated answer to me; reasonably accurate yet at the same time pretty much totally useless.
da
ok cool thanks
da
Aggiungi la tua risposta
robyn alker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 129
