Salta al contenuto principale
Officially marketed as Nerf Blasters, Nerf guns are toy weapons made by Hasbro that fire foam darts or, in some cases, foam balls.
20 Domande Visualizza tutte
Gun shoots with slmost no power at random
Hi,
I have a Nerf N-strike - Accustrike Alphahawk.
The blaster worked well for a few weeks but then It has started to shoot one or two shots per barrel (5 shot barrel) with almost no power. The dart basicaly drops out of It or It flies like one meter away which is not normal. The rest of darts in the barrel then usually is shot with full power again
Does someone please know what to do with it?
Regards
Petr
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
  • Inspect and replace darts if necessary.
  • Clean the blaster and barrel.
  • Check the barrel for obstructions.
  • Examine the plunger system.
  • Test for air leaks.
  • Adjust the spring tension if adjustable.
  • Ensure proper dart loading.
  • Check for internal mechanical issues.
Punteggio 0
Aggiungi la tua risposta
Petr Gabriel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 18
