Salta al contenuto principale
Is the Wireless Network Adaptor replaceable?
I have an ACER Swift X laptop (N20C12) . The Wireless Network Adapter was working intermittently and now will not see my wireless connections. I have reset the router and all my other devices are working and connecting. Can the Wireless Network Adapter be replaced? Is it on the motherboard? Thanks.
Questa è una buona domanda?
Punteggio 0
1 Commento
معمولاً با ریست کردن قطعه مورد نظر در تنظیمات ویندوز این مشکل حل میشود ، در مرحله دوم نصب مجدد درایور قطعه می‌باشد.
در صورت عدم کارکرد صحیح دستگاه ، از یک آدابتور اکسترنال استفاده کنید
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes the wireless Network adapter can be replaced.
Click here.
This is for the battery but shows you how to open the case and remove the battery. Never do any interior work without disconnecting the battery.
Go to Step 4 and the Adapter is right in the centre of the photo.
But first of all does it appear in Device Manager ? Is yes then right click delete it and then open "Action" menu selecting "Scan for hardware changes" and Windows will reinstall the driver.
Does it work now. Yes or no? If no replace the adapter.
Punteggio 1
Aggiungi la tua risposta
Ray sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 99
