Salta al contenuto principale
The 2014 edition of the Kindle, part of the 7th generation, includes a touchscreen and same form-factor as the Kindle Paperwhite, but lacks the backlight.
How can I fix my kindle Paperwhite screen separation?
I went into replace the battery and unfortunately the screen separated from the glass. (Bottom right corner) It's not cracked or broken but acts more like a protective film you'd put on your phone. When I try to push that area out like you would remove air bubbles, these lines go away for a second. So I'm assuming there was some sort of adhesive keeping the glass and plastic film together. Do I have to replace the entire glass or is there some way to salvage this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try mobile display adhesive glue on 4sides and fix it. Make sure to no slip during curing the gum with some tapes or rubber bands
Punteggio 0
Aggiungi la tua risposta
Liz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 206
