Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Domanda Chiusa
No imei, bluetooth, wifi. :(
Today i bought a iPhone 3gs 16gb black. its never been opened before. i opened up to see any damage . i changed 3 batteries but still same . i changed this logic board to another new working phone but same. i never seen a problem like this before. many people faced a problem of no imei or bluetooth. while restoring getting an error. but here different problem
NO error during restoring .
Not showing searching on the left side of the top corner only showing iPhone over there.
While updating an iPad baseband phone does not allow to flash it . on the screen this process not coming it directly goes for restarting the phone .
Questa è una buona domanda?
Punteggio 0
1 Commento:
this phone properly restored to latest version.
da
Aggiungi un commento
2 Risposte
It looks like the symptoms of a bricked baseband, however:
Make sure that you have all the parts completely screwed to the casing. It uses the case screws for grounding, and if a component isn't grounded, it won't work. Check all of your connections, and look for any damage to the board. There's a chance that you also may have bought a foreign logic board, and updated it with the wrong firmware/baseband. That would brick the baseband. However, you might have just gotten unlucky, and recieved a defective logic board.
I'd also try restoring from DFU mode, just to be safe.
Punteggio 0
1 Commento:
but this is a new problem . have you ever seen a problem like this . i also one white 3gs 16gb white and iphone4 16gb black that both is not properly restoring. it will give a error of -1 at last stage . why this iPhone fully restoring to its original settings. and it will always is in searching mode. but this phone will not going to searching at any cost there is always shown iPhone over there. only iPhone is written as the space of searching ...
da
I HAVE SAME PROBLEM I dont know hot to BACK UP or Restore it irestoret in last FINISH RESTORE i have ERORR MESSAGE -1 but i dont know how to back mu iphone 3gs like before so please if any body know the fix solution let contact me on koliqi@msn.com
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,377
