Why is my phone oveheating then I am using phone
why is my phone oveheating then i am using phone
Questa è una buona domanda?
what are you doing when it overheats?
if its gaming then its normal for it to get hot but if its overheating then its cooling solution needs replacing
A bad battery will overheat when drawing current from it. Batteries go bad because the internal resistance rises. Resistance generates heat. Heat further degrades the battery. Eventually the battery expands from the heat.
Time to get battery replaced.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 10
