Salta al contenuto principale
Repair information and disassembly guides for miscellaneous computer hardware devices.
13 Domande Visualizza tutte
Stripped Laptop Cover Screw
What is the best tool to remove a stripped laptop cover screw? I bought your small screw extractor but is does not do the job.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi there!
Dealing with a stripped laptop cover screw can be tricky. Here’s a suggestion to help you out:
  1. Rubber Band Method: Place a rubber band over the stripped screw head and press down firmly with your screwdriver. The rubber band can provide extra grip and traction to help turn the screw.
If the small screw extractor didn't work, this method might offer a simple and effective solution. Good luck!
Punteggio 0
Aggiungi la tua risposta
Steve Hills sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 40
