Salta al contenuto principale
The Dell G15-5510 stands apart from the 5511 by its 10th Gen Intel 10200H processor and GeForce GTX graphics. It hosts a wider range of ports, and it built with a sleeker design without sacrificing much performance.
I change my battery and is now working
I change my battery on my dell g 15 5510 with exact same specs 69kf2 and the laptop is not recognized the battery and now the battery led is flashing amber and white flash rapidly. This the battery that I ordered Dell 69KF2 Battery
Immagine Replace a 7167 mAh battery compatible with a Dell 69KF2 laptop battery. 86 Watt Hours (Wh). 11.4 Volts (V). Part #DVG8M, 8FCTC, P8P1P
Prodotto
Dell 69KF2 Battery
$89.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
The Dell support page (below) tells you how to fix this problem. scroll down to where it says "replacement battery is not recognized" scroll back up to the "expand all" then back down to the now visible instructions.
Good Luck!
Your Link: https://www.dell.com/support/kbdoc/en-us...
Punteggio 0
Hello, did you return it or managed to make it work. I have the same issue
Punteggio 0
Aggiungi la tua risposta
Mihai 18 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 50
