Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Domande Visualizza tutte
Mircophone socket broke off from the logic board
Hi guys,
during the replacement of my display I was not careful enough and broke off the microphone socket from the logic board. MacBook Core Duo Display Replacement -> Step 27.
I insulated the microphone cable and I would like to know if there will be any problems with that solution?
Will a headphone including a microphone function work on this Macbook?
Thank you for your help!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Get a USB audio adapter. You can use it to plug in the microphone. When the microphone connector is not connected to the logic board it will not work. Adapters can/should have both mic in and line out connectors on them.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 2
2 Commenti:
Thanks for your answer! I tore off the microphone including the socket from the logic board, so this solution will not work for me. Is there a possiblity to solder it with a soldering iron?
da
The USB port has nothing to do with "microphone port". Soldering of computer logic boards requires special solder, iron & skills. Logic boards are easy to destroy. Not really a DIY sort of thing.
da
Like MacUser, I tore off the socket from the logic board. When you say "Get a USB audio adapter. You can use it to plug in the microphone." are you also saying to get a plug and play microphone or that the current MacBook microphone can work with the audio adapter?
If I prefer to have no external mic, is this a shop repair or totally unrepairable?
Punteggio 0
1 Commento:
ginamayb - For future reference you posted a comment in the place where only Answers belong. Please use the Add Comment link, or start your own Question. For clarification: a USB adaptor will not repair your onboard socket, its a "workaround" you can use the adaptor - replace or professionally repair the logic board, or, use as is.
da
Aggiungi la tua risposta
MacUser sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 538
