How to fix an oil leak on 2002 lexus gs300?
Found an oil leak under the engine on my 2002 lexus 300 how do i figure out where its coming from and how do i fix it?
Questa è una buona domanda?
Oil falls down. Put a piece of cardbord under the car to determine where it is falling from. Then inspect the location above that.
History would be good to post. Like did you recently have the oil & filter changed. Did you go offroading with it. The more info the better
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 22
If you don't know how to find the leak then you probably don't know how ti fix it. You'll probably ruin your car if you try to do something you don't understand.
da Vertinhol
