How can I fix my car cruise control?
My car cruise control doesn't work properly. Sometimes cannot be activated to maintain a specific speed.
Is it possible to repair it by myself?
Questa è una buona domanda?
hello, generally you can repair it, the main issues with cruise control are the pedals sensors, in normal operation when you press the brake pedal or the clutch pedal (sometimes accelerator too) the cruise control stops from working, if the sensor is old and isn't positioned correctly it can trigger a false positive information, and the cruise control detects it as you pressed the pedal and stops working.
Thanks alot !!
No problem :)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 15
Tutti i Tempi: 112
