Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
Domanda Chiusa
Digitizer not functioning well.
iphone4 16gb stop responding to touch after talked on the phone. it was working well before i listened to call for near about 40min. after disconnecting the call touch of phone not working. i restored the phone 2 times. check the internals . nothing found out. changed the screen 3 times from the market and 1 from the working phone. touch of this phone is working in another phone but not in this phone. i takes out the logic board and remained un contacted from battery for 30 mins but still same . logic board looks fresh. phone never opened before. i checked only. help.........
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
First, this is going to need a new display assembly. If that doesn't work, then it's the motherboard in the phone, or simply a defective replacement. Get another one if this is the case to confirm.
Sostituzione gruppo display iPhone 4
Should this be the motherboard, don't bother fixing it. The boards cost more then a phone and you have to be careful, since some of them are IMEI/ESN blocked. You can't verify a lot of these, since some sellers don't know or evade the question for obvious reason. I wouldn't bother.
They can also cost more then the phone is worth at times.
Punteggio 1
5 Commenti:
i changed so many . the problem is in the logic board . have any idea ? i found 2 chips are responsible for this but very hard to get that .
da
You need to know compoent level soldering, whicj is that tough
da
yup i will try with that . otherwise last option is to replace the logic board
da
like I said, you need to compare the cost and find the best deal, DO NOT buy used boards due to the IMEI block risk, only time you do is if you get a cracked 4 on craigslist and it is not stolen, and the IMEI is clean and checkable
da
Here in india apple is replacing the phone on chargeable basis. i will go there becoz they are giving a new phone. then thats it the better option.
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,887
