Salta al contenuto principale
Repair information for the Brother DCP-T300 printer. First available on Amazon in January of 2017. Model number: DCP-T300.
14 Domande Visualizza tutte
Why is my black ink not working?
Every time I print a document, the black ink is not working even though it has an ink inside the cartridge
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Hi,
Have you check the ink is able to flow from the cartridge or the container to the printhead ?
If not you're printhead is clogged.
BR
Artefil
Punteggio 0
hi just go to menu settings deep cleaning press (menu + mono +menu) then press upward 7 and 6 and then press upward select black.
Punteggio 0
Go to the menu and maintenance and you will find a option for cleaning select black and use the strongest setting the printer will clean the ink head for you and it should work greatly after that
Punteggio 0
Aggiungi la tua risposta
JARZELLE DE LEON sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 96
Tutti i Tempi: 327
