Salta al contenuto principale
Il Western Digital My Passport Ultra è un dispositivo di archiviazione portatile USB 3.0 con capacità da 500 GB fino a 5 TB.
Prying open hard drive
Hello - the actual external hard drive I have is a Western Digital easystore 2TB hard drive. The reason I chose the My Passport Ultra is because its practically the same size, form and shape as the easystore EXHD I have. Unfortunately earlier this year when I was getting my new computer all setup, I dropped this hard drive of mine on the floor as it was on top of the CPU. Now, the hard drive just makes a clicking noise every time I plug it in. I wanted to see if there was a way I can extricate the hard drive itself from the case and use a recovery reader I have . However, it seems impossible to do with no way to slither my way through the edge of the hard drive casing.
Immagine
Thank you
-Jordan
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta più utile
That's fairly risky if it is your first time. there will be tutorials available online. since it can be risky make sure to clone your drive before hand. a lot of free tools out there. you can use Remo Free Disk Clone Software if you want a fast and effective option.
However, I would insist that you simply just take it to a shop as a lot could go wrong here.
Punteggio 1
@jordan18927 yup, same tabs. You may just need to change the "angle of approach" and a bit more rigid tools. Check on here for the how-to proceed. this is just an example and not an endorsement
Punteggio 0
Aggiungi la tua risposta
Jordan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 15
Ultimi 30 giorni: 85
Tutti i Tempi: 1,752
