Grinder motor not turning on - conical burrs already replaced
Jura C9, worked flawlessly after brew group refresh 3 years ago. Now getting a "Fill Beans" error, no coffee, no grinding. Replaced the conical burr grinder gears and reassembled. Grind motor is not turning on when you try to brew.
Motor is not getting power during brew as verified via a meter. So I'm assuming there is/are 1 or more inline fuses I need to find.
Has anyone run into this problem? Where do you source replacements?
Thank you
Questa è una buona domanda?
1 Commento
@bradnic let's see if the iFixit guru @vauweh has a trick up his sleeve ;-) to help you out.
da oldturkey03
