Salta al contenuto principale
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
Why doesn't my 3DS read cartridges?
I have modded my 3DS so I can open up GodMode9 and whenever I put any cartridge in, I get the message "Game card init failed!" On the regular 3DS home screen it instead just doesn't show up. I shined a flashlight into the game cartridge slot and I can't really tell if the pins are bent. So the 3DS can detect the cartridge but it can't read it? This has stumped me for a while. It's possible I could of broken it by inserting an incredibly dirty DS download station or a R4 flash card.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi!
Well, I can't help you with the CFW. But if the game doesn't show up at all in the 3DS home menu, then it's probably the game card reader which need a replacement.
Luckily the game card reader is modulair, so you can replace it without soldering.
Guide: Sostituzione del lettore di schede di gioco del New Nintendo 3DS XL 2015
Part: Nintendo 3DS XL (2015) Game Cartridge Slot
Good luck with the repair and let us know how it goes!
Immagine This part is the physical mechanism that holds the game cartridges in the Nintendo 3DS XL (2015).
Prodotto
$19.99
Punteggio 1
6 Commenti:
Its modular?? THANK YOU NINTENDO!! Was so worried about soldering, I've been trying to learn how to solder, but I'm really not experienced at all.
da
Yeah it is! Haha, Nintendo is improving a lot these days to make repairs easier. Soldering is required for the previous models, so you’re lucky! Good luck with the repair!
da
@michaelepica @dan0 i think replacing the whole slot might be overkill here. Just put a bunch of isopropyl alcohol on the pins of one of your carts and push it in and out of the reader several times to clean the pins. (of the reader, not the cart)
da
@darthmango is right. Lets try to clean it first. I should have thought about this, sorry.
da
I would say what if I broke it, but like, well
da
Mostra 1 altro commento
f possible test various Nintendo 3DS Game Cards in your system. If only one Game Card does not work in your Nintendo 3DS system, please check if this Game Card works properly in another Nintendo 3DS system. If the error also occurs with another Nintendo 3DS system, the Game Card is faulty.
Punteggio 0
Aggiungi la tua risposta
MichaelEpicA sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 54
Tutti i Tempi: 380
