Salta al contenuto principale
My call cut automatically and says server is unreachable
My phone call is cut automatically and says server unreachable
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You might be using Wi-Fi calling, check in your phone's settings if Wi-Fi calling or "VoIP" is enabled and turn it off, you can also try to make the same call while not connected to Wi-Fi.
this feature lets to route calls over Wi-Fi to improve calls in areas with weak phone signal, but not all phone networks support this fully, and it might not work on some Wi-Fi networks.
Punteggio 0
Aggiungi la tua risposta
Hdisie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 144
