Salta al contenuto principale
Il DJI Mini 2 è un piccolo drone prodotto da DJI nel 2020. Il DJI Mini 2 offre video 4K/30fps e una trasmissione video da 10 km a 720p/30fps.
incompatible gimbal data error
powers on connects to drone, camera rotates left,right, up and down can view through camera. gimbal does not respond to wheel on controler. has incompatible gimbal data on display. will not take off. is i a board problem or a cable
Questa è una buona domanda?
Punteggio 1
1 Commento
did you solve this problem?
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
Let's do a little logical thinking here.
If the gimbal does its power on movement then the gimbal and cable to it from its controller in the AC are functional.
If you can view the camera, then the camera system and communication from the AC is functional.
The AC sees the gimbal and is getting data but does not like what it sees, so you are getting an "incompatible gimbal data" message.
Therefore, any commands to it from your Controller are ignored (or maybe the Controller isn't even sending the commands because of the error).
If that message appeared after your "minor" crash, then I would first suspect a dislodged cable in the AC.
But after that, a damaged PCB is a possibility.
Punteggio 2
3 Commenti:
I'm afraid the reader does not know about an AC being Altitude Controller, nor where to locate this in the drone...
da
AC is a common abbreviation for AirCraft
da
gps board ended up being culprit,bought new still didnt work, took board from another broken drone and all well now.
da
You will need to replace the gimbal. The best website to buy parts from is: djioemparts.com.
You can buy a new gimbal here for $80 USD https://djioemparts.com/collections/dji-...
Best of luck, BetaTech Labs Repair AU
Punteggio 1
2 Commenti:
the gimbal responds to startup/power on and does up down left right chk ok and i can view through camera, does not respond to up/down knob on controler so would that be gimbal or motherboard
da
did it beep at startup?
da
Hi, Have you done any repairs recently? have you crashed recently?
Punteggio 0
4 Commenti:
very minor fall from about 8' into grass
da
Yeah, it looks like you messed up your gimbal
da
posting new answer...
da
finally was able to find solution, i replaced gps board and all is once again fine!
da
Aggiungi la tua risposta
colderp sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 20
Ultimi 30 giorni: 80
Tutti i Tempi: 2,831
