Salta al contenuto principale
BeagleBone Black is a model of BeagleBoard introduced in 2013
Power light on then immediately off
Checking across most capacitors (like C2) reads almost shorted so I assume a component has failed. Short appears across the whole board so I assume a main power rail short and once the power regulator sees the short on the output it shuts down. Anyone have any guesses on which component(s) may have failed. I have 2 BBB with the same exact issue.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
In my opinion, your BBB may have a broken power management chip or some shorted diodes. If all shorts disappeared after removing power chip, the power management chip must have a problem.
If not, other components(or both them and chip) have problems.
Punteggio 0
Aggiungi la tua risposta
Techni Plex sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 251
