How can I repair my laptop battery
My laptop battery get slowly charge and get fastly discharge
Questa è una buona domanda?
So this isn't that clear of the problem, when did this become an issue? What were you doing when you noticed? Are you gaming/using high performance mode? Is your brightness all the way up? Are you using the correct charger the one that came with it from the manufacturer? You can't really repair a battery unless you are a professional and have the tools, you would be better off just buying a new battery.
What CodyW said. But note that LT batteries usually go bad because 1 or 2 of the cells (18650) go bad. There are still 4-6 more that are good. I take them apart and use the good ones for my flashlights and other things that use 18650 cells.
Still probably cheaper to just replace the battery.
Amazon or E-bay have aftermarket ones that are usually inexpensive.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 53
