Salta al contenuto principale
Realme C3 is a low budget Android smartphone developed by Realme. Released in February 2020 in India and March 2020 in the Philippines.
Why does my phone continuously switch off and switch on
I can't use my phone cause it starts switch off and swich on till bettry gtes completely empty
Questa è una buona domanda?
Punteggio 2
5 Commenti
My phone switch button not working
da
Battery problam
da
Power button
da
Display change
da
Family display change
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
@bhavikrathod could be a bad battery issue. Make sure that it is fully charged and if it does no longer hold a full charge, replace it. Since iFixit does not yet have guides for this use something like this video Now, with a new battery and if it still is doing this, Try to start your phone in safe mode.
  1. Turn off the device
  2. Press and hold the power button until the Realme logo appears
  3. When the Realme animation logo screen appears, quickly press and hold the volume down button and power button until the device reaches the power-on process
  4. Safe mode will appear on the lower left side of the screen in a transparent style
If it has stopped to turn on and off in safe mode, you know that the issue is related to a bad third party App. You will have to delete one after the other until you know which one it is.
If none of this works, you may have to try a factory reset. This will not work if your phone continue to turn on and off. For the How-to on that use the information from here
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 2
Here's what you can do:
  1. Check for software updates.
  2. Restart your phone.
  3. Boot into safe mode to check for app issues.
  4. Inspect for physical damage.
  5. Consider a factory reset.
  6. If the problem persists, it might be a hardware issue. Contact Realme support or visit a service center for assistance.
Punteggio 0
3 Commenti:
@tabathakang you continue to prove that you are missing the point of this site. I can't figure out if this is based on purpose or if it is based on your AI usage. AI doesn't care, I get that. You as the owner of the answers, should care. Those are your responsibilities.
Let me explain to you what is so fundamentally wrong with your answers. Your AI is not explaining anything. Ask yourself if you could fix a single device by following your answers. You know you couldn't. AI is not explaining how to check for updates, how to restart, how to boot in safe mode, what physical damage to inspect or even how to do a factory reset. You are providing a lot of BLAH BLAH BLAH but nothing even remotely helpful. Train your AI and stop using Google and Bing as the source. If you can't train it, don't use it! WEAK! Very Weak.
=== Repair is War on Entropy!!!! ===
da
how to fix how to fix my on off button not working what should i do
da
@khemirkhal50165 try the solutions mentioned in the Answer. Let us know what, if anything, worked.
da
Software kasa mara
Punteggio 0
Aggiungi la tua risposta
Bhavik Rathod sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 91
Tutti i Tempi: 1,365
