Salta al contenuto principale
Is it possible to replace the hard disk with an SSD?
I would like to clone the current HDD with an SSD to make it faster.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@piero90 yes, you can. Now, with that said, it will depend on what motherboard/processor you have. If your motherboard does not have an M2 slot, you will need to get a 2.5" SATA3 SSD. Something like a Kingston’s KC600 would work
If it does have an M2 use the appropriate SSD for that.
"Support for 6.35-cm (2.5-in) SATA hard drives in 7.0-mm (.28-in) and 9.5-mm (.37-in) thickness Support for M.2 SATA storage (Port 0) (models with i7 processors and 4 GB discrete graphics memory only)" from the HP Envy Maintenance And Service Guide. Page 55 shows you how to check it out and to work on it.
Punteggio 2
7 Commenti:
Is the following docking station good for cloning laptop HDD to SSD?
https://www.amazon.it/Inateck-Dual-Bay-f...
da
@piero90 I have not use that particular one but use a similar setup daily without any issues.
da
@oldturkey03 Good evening, this SSD is good for notebook?
https://www.amazon.it/Samsung-Memorie-MZ...
da
@piero90 Looks like it should work, 2TB :-) Awesome!
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Piero Sabino sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 139
