Xbox powers up but does not show picture
Starting a week or so ago my Xbox One S no longer appears to work. I can turn it on (the white Xbox button lights up), but it never send a signal to the TV. The fan will also start spinning (it was replaced a few months ago).
Whenever it's first plugged in, or when I a press the button after it sitting for a while, there is a faint beeping or buzzing sound coming from the Xbox. One short sound, then about a second of silence. It'll do that 8 times then have a longer break, and then start the sequence over again. After a while it stops doing it until you press the on button again.
It's pretty quiet but you can hear the beeping/buzzing in this video:
So far I've tried the following but with no luck:
- Full power reset (turn off for 30 seconds, unplug, etc)
- Hard reset using the power button
- Connect to different TV, using a different power cable and a different HDMI cable
- Booting into low resolution mode
- Pushing the eject button repeatedly when booting
- Inserting and ejecting discs while booting
Are there any other things I can try to troubleshoot what the issue is? I'm wondering if it's maybe the hard drive, but how would I be able to tell?
Questa è una buona domanda?
