Salta al contenuto principale
GoTab Android Tablet Advice Needed
Hi all, I'm new to electronics repairing world,
I've purchased 10 x GoTab tablets for spares or repair but can't find a guide on your site. As I'm new are these all made in the same factory with different brands Are all android tablets basically the same under the cover?
Thanks for all help?
Update (04/21/24)
Also I'm after what should be done in the situation. Should I assume that a device that won't turn needs a new battery or check the battery with a multimeter. The items have I presume been in storage.
Questa è una buona domanda?
Punteggio 0
1 Commento
I've also noticed that there are some Versus branded tablets. Also looking at the original advert it states you could make two good tablets from three as all parts are interchangeable and should take 15 minutes to make a working tablet
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
get a usb amp meter it will help determine if the tablets are charging
Punteggio 1
7 Commenti:
Hi apologies for the question what sort of meter should I be looking for
da
Thanks for the suggestion
da
Have ordered the meter and will let you know when it's arrived
da
Hi the meter has arrived . What do I do with it now?
da
Mostra altri 2 commenti
I've been made redundant in my day job and will wating to get a job I will have time to to fully learn how to get know how the USB meter works sand get the original tablets together.
Punteggio 0
Aggiungi la tua risposta
JimEssex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 162
