Salta al contenuto principale
The HP Pavilion dv4000 laptop (model number: EC681AV) was released in March 2005. It runs on the Windows XP operating system.
HDD yerine SSD takabilirmiyim?
Hello, I am using an HP Pavilion DV4000 laptop, but it lags even while watching YouTube. I use 1gb and 256mb ram, the processor is Intel pentium 1.67ghz HDD, it is very slow and that's why I want to install an SSD instead of HDD. Is it possible to replace these parts? Which components do it support the most?
Questa è una buona domanda?
Punteggio 0
1 Commento
So, which processor does the motherboard support the most? 32 bit, 64 bit? Does it support i5 3210M or i5 3470? Note:DDR2 Motherboard
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Furkan,
Based on what i've seen online, it's likely possible for you to replace your HDD with a SATA SSD. I would recommend the Samsung 870 evo SSD or above, depending on your needs for capacity and speed.
Punteggio 1
Aggiungi la tua risposta
Furkan Ali Şahintürk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 127
