Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
Dead power button fix
My 2015 MBP has a dead power button. I have determined that it is completely dead at the contact pad as if I touch it with something metal, it doesn't work. Every other key works. Is there something I can do, or does the whole keyboard need replacing?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
To be clear, you are able to power on the system by shorting out the Power Pads, so it’s clearly the button that’s failed.
Punteggio 0
2 Commenti:
I haven't tried that. I may have to replace the entire top case.
da
@sickminecraft45 - I would start off checking if you can bypass the keyboard first.
da
Aggiungi la tua risposta
Sickminecraft45 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 180
