Salta al contenuto principale
Lanciato a novembre 2020, il MacBook Air da 13" usa il SoC (sistema su chip) basato su ARM M1 di Apple, con una CPU octacore e una GPU che può arrivare fino a octacore. (Modello A2337 / EMC 3598 con due porte Thunderbolt 3)
189 Domande Visualizza tutte
funky stuff going on with display
this macbook works fine hooked up to an external display, but it's built in is only backlit. The built in is the original built in display from another macbook of the exact same make and model. In the system info app i can tell that the computer recognizes the fact that the display is here and it is connected into the display, there isn't an error showing and i'm confused. I guess what I am wondering is why i can see everything totally fine on an external display, but i only have backlight on the built in, with no errors showing?? Thank you!
Update (04/16/24)
I would like to add that I’m using the exact macbook on an external display to write this.
Also - this exact built in screen when it was on its original computer before I put it on the one I'm on now, it had the same issue, I moved it over because I thought it was a software thing.
Update (04/16/24)
here is a picture of it
Questa è una buona domanda?
Punteggio 1
3 Commenti:
sorry the room is messy
da
@jack_likes_tech your room is fine, should see my shop:-) Anyhow, quick question. Why did you replace the original display?
da
because it was cracked and was all wrong colors and then I bumped it on something and the backlight turned off
da
Aggiungi un commento
1 Risposta
Diagnostics and hardware inspection tools don’t test beyond the logic board.
As you can see your system via the external display your internal display is damaged.
Can you post a picture from your cellphone camera or other camera so we can see what you see here so we to can see.
Punteggio 0
3 Commenti:
i posted a photo
da
@jack_likes_tech - Sorry, you do indeed need a new display assembly. Here’s the guide to replace the display Sostituzione schermo MacBook Air 13" fine 2020
da
darn, ok, thank you!
da
Aggiungi la tua risposta
jackypoo100 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 69
