Salta al contenuto principale
The first generation of the executive car by Volvo known as the S80.
How to remove a key stuck on ignition
How can I remove a key stuck on the ignition
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Collings, does your car have an automatic transmission? If so, the gear selection lever must be fully in the Park position in order to remove the key from the ignition switch. Try moving the gearshift to a different position, then make sure it is securely positioned in Park, at which point the switch should allow you to turn it to the off position and remove the key.
If that doesn't work you may have to troubleshoot the mechanical connection between the gearshift and the ignition switch.
Punteggio 1
Aggiungi la tua risposta
Collings Manda sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 204
