Salta al contenuto principale
The iMac Pro, is Apple’s most powerful iMac to date. It comes with either a 3.2 GHz 8 core, 3.0 GHz 10 core, 2.5 GHz 14 core or 2.3 GHz 18 core Xeon W processor. EMC 3144 / A1862 (ID iMacPro1,1)
20 Domande Visualizza tutte
iMac Pro / Motherboard dead / No leds on
Hi everyone, I have an issue with my imac pro. It doesn't start anymore.
I have no leds light on motherboard. I already changed power supply but same thing. Thank you for your help.
Regards
Update (04/19/24)
Mise à jour...
Je me suis rendu compte qu'il y avait un bouton sous les leds sur lequel il faut appuyer pour avoir l'état.
Seul la première led s'allume. J'ai également essayé de me connecter en DFU et j'y arrive par contre j'ai une erreur quand j'essaie de restaurer.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
I would check the AC socket as well as manually short the power button line to see if the button has failed as well as check the power rails.
It’s also likely you have a short within the logic board logic. You need the schematics and board views to work this out.
Punteggio 0
I have the same issue. Power supply is good, power does come in to the power supply but the LEDS are out.
Punteggio 0
1 Commento:
Under and to the right of the leds is a push button. The leds will not enable unless this button is pressed.
da
Aggiungi la tua risposta
Olivier Paulart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 102
