Salta al contenuto principale
Sony digital camera in the Cyber-shot series. Shoots 6 MP photos and is released in 2006.
Lens is stuck halfway
My Sony DSC-H2 was working fine until recently. The word 'Access' appears when you start it up, indicating that there's a problem with extending the lens. The image is fuzzy and can't be focused. When I try to power it off, it tries about three times to retract the lens but then gives up and leaves the lens half out.
I've tried new batteries and a factory reset of the camera.
Any help appreciated.
Questa è una buona domanda?
Punteggio 1
1 Commento
Tengo una de este tipo y le dieron un golpe y al encender el lente no trabaja no enfoca
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@randominion7494 your camera has a stuck lens. Try the tips fromthis site If none of that works, you may have to replace the lens. To work on it use this teardown Sony Cyber-shot DSC-H2 Teardown and the Sony instructions right here DSC H2 Disassembly
Punteggio 1
1 Commento:
Thank you for your suggestion.
da
Aggiungi la tua risposta
randominion sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 110
