Understanding SMC Panic Assertion Failed codes
Hello!
I'm not sure what error code I'm getting, it shows as follows:
ASSERTION FAILED: target\/d27\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x40000000
My understanding is:
0x40000 is the charger port flex
0x400000 is the wireless charging flex
But I'm getting 0x40000000. What's this? I can't seem to find it anywhere else.
Update (04/01/24)
Bump. The phone's stuck in a reboot loop and every loop generates this panic. Any help appreciated, at this point just trying to keep the phone on long enough to back up the data.
Questa è una buona domanda?
@flannelist you are the Guru on this stuff. You got anything up your sleeve to help the OP with this?
da oldturkey03
This one might need some math. Could be related to multiple parts, @petitepata72947 what preceded the boot loop? Is it damaged in any way?
da Alisha C
No damage that I can tell in any way, no.
Preceding the loop, it took a full charge, and the next day as the battery was getting low (but not yet sub 20%) it turned off. When it turned back on, it displayed the unable to verify genuine battery message, 0% battery, and would no longer charge.
When plugged in or in wireless charging, it vibrates but does not display the charging.
da petitepatate
