Salta al contenuto principale
Repair and disassembly information for Google's Pixel 8 smartphone, released in October 2023. Identified by model numbers G9BQD, GA04851-US, GKWS6, GPJ41, and GZPFO.
do I need to replace the adhesive?
If I open it up do I need to replace the adhesive?
Questa è una buona domanda?
Punteggio 1
1 Commento
Short answer. Yes.
Longer answer. Depending on where you open it up you may damage the adhesive and it will be safer to replace it than not doing it. Replacing it will also ensure liquid resistance is kept.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I would recommend replacing the adhesive after you open the device up. The adhesive helps ensure dirt, dust, and water doesn't get into the device. Not replacing the adhesive could result in moisture damage, which would end up costing you far more than the relatively small investment.
Google Pixel 8 Screen Adhesive - Genuine
Immagine This custom cut adhesive film secures the display panel to the frame of a Google Pixel 8 smartphone.
Prodotto
$3.99
Punteggio 1
Aggiungi la tua risposta
Grayden Hormes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 200
