Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
Adhesive remover in screen
please help my the adheasive remover got in my screen and it is squelching around i can see the liquid moving what do i do to get it out
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
I'm not sure what adhesive remover you used, but if it is alcohol or water based, it should evaporate over time. However, it may leave some traces behind. I would start by turning the laptop off and disconnecting the battery (if possible) and letting things dry. Opening the display assembly is very difficult on these models so this may be your only option.
Try to leave the laptop somewhere warm and dry to speed up the evaporation, and cross your fingers that the display isn't damaged.
Punteggio 1
Aggiungi la tua risposta
User: Failure sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 108
