Salta al contenuto principale
Released March 2021, this model features lidar, a gravity-fed vibrating mop pad, and mop pad lifting using an ultrasonic carpet detector.
Roborock s7 - side brush keep falling while in use
Hey,
My Roborock S7 is 2 years old and lately, the side brush started to fall off during operation.
I keep finding it in different areas of the house, this is annoying.
When locking it back again, it feels like the screw is tight.
Any idea how to fix it?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
I had the same problem with mine. used some super glue. can recommend
Punteggio 0
1 Commento:
super glue?? and what happens once you want to change the brush?
da
I also had the same problem with mine.
After screwing it on several times, I decided to use a little dab of Loctite.
I really can’t recommend that because it almost certainly led to the failure of the side brush motor.
Punteggio 0
Aggiungi la tua risposta
rot253 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 873
