Hi @mohammedfa57539
When you can get the phone to turn on, try starting it in safe mode and check if the problem occurs or not.
This is just to eliminate whether a downloaded app may be causing the problem.
If it still occurs in safe mode, backup the phone to the cloud or a computer and then perform a factory restore¹ and check if the problem occurs.
¹ Be aware that a factory restore will erase all your personal data and downloaded apps. It will reset the phone back to its factory default condition. That is why it is important to backup the phone first, before performing the factory restore. Also if there's a Google or Samsung account tied to the phone, you will need to know the user ID and password for the account to enable you to setup the phone again after it has been reset. This is due to the FRP lock (Factory Reset Protection) that has been enabled by the reset.
If the problem still occurs in the factory default condition, then it is a hardware problem which would have to be further investigated. Does it do this if the charger is connected to the phone? Has the phone been dropped or gotten wet at all?
If the problem doesn't occur in the factory default condition, restore the phone to what it was before the reset by using the backup that you made earlier and check if it is still OK. If so then the reset has resolved the problem.
Note: Being random makes it difficult to know so if you decide to try the above allow sufficient time with each test to ensure that the problem is either still there or it isn't.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
