Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
Mac Mini 2014 missing bottom cover. is this a problem?
I have obtained a mac mini 2014 that is missing the plastic bottom plate cover. Is this a problem? Does this block airflow, and if so, would this be mitigated by adding feet to the base of the mac to give raise the device a little to allow air circulation? are there any other issues that will need to be worked around?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I'd recommend adding the feet onto the Mac as it would allow for improved airflow into the device. But other than that I don't think it should be too much of an issue.
Punteggio 2
2 Commenti:
It might be just worth the expense to replace it here's the needed part Mac Mini Bottom Cover (used) $11 USD
da
Thanks Dan. I had searched for these online but had not found one with reasonable postage to Australia. I have bought this one as both the price and postage were reasonable.
da
Aggiungi la tua risposta
James sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 196
