Salta al contenuto principale
Ninth generation of iPad, released September 24, 2021, available in 64 or 256 GB models. Model Number A2602.
Toch ID doesnt work
Hey. The Touch id stop working. Can i buy a new one. Or is it like an Iphone when you buy new home buttom the Touch id stop working becuse its not an Original. Or does it work with just a new buttom. Or whats else can be the problem?
/ Markus
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Markus,
The Touch ID function on an iPad does indeed work just like that of an iPhone; the button is paired to the motherboard with a proprietary encryption algorithm that only Apple has access to. As a result, only Apple can replace the button and restore Touch ID, but unfortunately, they don't offer repair services for iPads.
So yeah, basically you're out of luck as far as replacing a broken button. You can get one that will function normally as a home button, but say goodbye to Touch ID.
There are some specialized services like iPad Rehab that have the skills to repair damaged buttons, but of course there's no guarantee. That's going to be your best shot at getting it working again, but it's likely not going to be cheap.
Punteggio 1
2 Commenti:
Okey. But when does it comes out on the 3e market. I mean Eeeeverythings else is out. like batterys lcd and so on. The only things left is Touch id =D
da
@markus33990 Never. The parts are tied together with an encryption code that is unbreakable and only Apple has access to it. It is impossible for anyone else to duplicate the code without the algorithm used to generate it. Same thing goes for Face ID and an increasing number of parts used in iPhones, MacBooks and iPads. Batteries and screens are now paired on iPhones and will result in loss of function when replaced.
da
Aggiungi la tua risposta
Markus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 168
