Ps4 won't accept game disk
Why won't my ps4 accept game disk like when I try to put a game in the ps4 won't take it
Questa è una buona domanda?
Will it engage the rollers or is it completely dead?
When you try to insert a disc, does it feel like there is a physical obstruction? Can you manually push it in with little resistance?
PlayStation 4 Optical Drive Replacement - iFixit Repair Guide
Physical Obstruction: Following the above guide will get you access to the drive. If there is any obstruction inside the drive like debris or another disc, you can manually free it by using the manual release. If it is dirt, then you can try CAREFULLY disassembling the drive (lots of gears and some springs).
Any other: It could be a component on the drive board or the controller on the drive board. If that's the case, you will need a paired drive board/motherboard combo.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 15
