Won't Drain on Primary Setting
Did you ever figured out what was the issue ? I have the same problem with a Kenmore laundry center
Questa è una buona domanda?
Seems as though it may be a faulty or worn washer timer operating cam or contact.
Here's the service manual¹ for your model series laundry centre that may help.
Unfortunately if the timer is faulty it will have to be replaced, mainly due to the fact that there are no internal replacement parts for it. It is a complete module. Do not attempt to open the timer to find out what's wrong because if you do and you're not careful you will have cams and contacts flying everywhere ;-)
On p.95 of the manual it describes the procedure to remove the washer timer. The timer's part number is 134237200. Search online for the part number only, to find suppliers that suit you best.
¹ Your model is a Frigidaire model made for Kenmore as it is comprised solely of Frigidaire parts.
Hi @jayeff
Yeah that’s what it seems like, now thinking about buying a new washer/ dryer since it’s an old unit giving lots of issues lately or replace the timer which is couple hundred bucks , thank you
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 26
2 Commenti
Hi @antonioquir1245
What is the model number of the laundry centre?
Note:
I've moved your comment to a new question so as to enable it to more relevant answers, as you posted your comment in a thread about Maytag washers.
Moderator.
da jayeff
Hi @jayeff
Is a Kenmore Model # 41797922701
It would go to wash cycle and after that the timer will continue and won’t drain and it will start spinning, dumping the water out on the floor . It drains / works normal in rinse and spin .
Thanks
da Antonio Quiroz
