Machine Agitates but won't spin
the machine will not spin but agitates and drains. I changed the coupler and the clutch but it still won't spin. The motor runs and I can hear the change when I change speeds but the tub will not spin. Also, the tub is very hard to spin manually. Is this the transmission or the tub causing this?
Questa è una buona domanda?
6 Commenti
Hi @njbob,
What is the model number of the washer?
da jayeff
Hi - it is 110.20952992
da njbob
@njbob
Can you manually rotate the tub in both directions or only the one way?
da jayeff
I can spin it both directions - tight but it moves
da njbob
@njbob
Check the agitator dogs are OK.
They prevent the agitator from rotating in both directions as it should only rotate in the one direction
da jayeff
Mostra 1 altro commento
